I have some code created from Fusion 360 that drills a bunch of holes. When I ran the code it went down to make the hole, but it looks like it did not retract correctly and started moving to the next location while down. I managed to hit the e-stop, however it did ruin a nice piece of walnut.
Before I ran the code, I double checked the zero point to make sure it was correct but telling the controller to goto to z0. The zero point was correct before, so I ran the code.
I have few questions:
Does the controller support the G98 G-Code?
Is the code correct?
In line 50, (N50 G98 G81 X2.625 Y2.625 Z-0.75 R-0.1 F30) is the retract above the top surface. If so then, I’m not sure where this comes from as in the file the retract height is set to .3
Does the rest of the code look correct?
It seems to me your “R-.1” value would be the issue. I would think that needs to be a positive value, assuming you have set Z zero off the top of your work piece. I would say double check your Heights again in Fusion.
I haven’t received my machine yet so take this as it comes. My machine will hopefully be here in another week or two!
I am having this same issue. According to the documentation of G81 it should return to the last Z value if that value is greater then R. and only return to R if it is greater then the Z at the time of execution. My code below should return to Z5 not the R-2.35 but currently the retract is always to -2.35. G90 is declared at the top of my Code.
Looks like fusion 360 has a problem G98 should retract to the last Z before the G81. That being said your R should only be a negative if your drilling a surface that is below your Z zero. That is the purpose of G98 it allow the tool to rapid to a negative R but retract to above the surface of the part. G99 will retract to the R plane.
This also just happened to me. Simulation shows a proper retraction, no collisions. The drilling retracted but not to a safe distance, cutting through around 1/8 of material from the first drill to the second.
After drilling the first hole the tool should retract to the Z height before the G98 code was issued, since 0.5 is higher than 0. When I run the Fusion 360 simulator, that’s what happens. However the Onefinity only retracts to the R0 height. it appears that the G81 command is ignoring G98. I manually edited the G code file to change the R0 to R0.5 and it ran correctly. This appears to be a bug in the controller.
FYI I just noticed that if you look at the Cheat Sheet screen on the Controller, G98 is not supported, so is just ignored by the G81 command. I’m still somewhat new to this so I wonder if there’s some way to tell Fusion 360 not to use it when it generates the G code.
