How do i cut a simple edge profile easily?
I have a bunch of parts that will fit together to make a uniquely shaped box. Most of the edges need to be cut on an angle but they are all different. Is there an easy way to load each 3D model into Aspire and cut these profiles? I saw videos on using a molding path but that means I have to set up a path for every single angle which is what I want to avoid if possible.
Image of example part:
If it is a 3d model, use a ballnose cutter and a 3d finish tool path. You probably should take this to the vectric forum.
