First time I have made one of these. Bass wood with two coats of seal coat on it but I’m completely at a loss as to how to finish it. Don’t want to paint it. Any suggestions?
Then you could have used any stain.
I forgot, you could use glazes too.
Sometimes I stain, then seal, then use water based paint.
Use your imagination!
Pony
Unsealed/before sealing, I sometimes use dye in alcohol. Alcohol lets me move it around, blend it, and target grain for darkening/color change even after it dries (assuming an alcohol soluble dye )
For example, black dye sanded back with a high grit leaves the grain darker and the non-grain parts the base color of the wood. I can’t find any examples I’ve done on my photos but here is one I found
