I’ve been thinking about rotating the table 90 degrees to put the side against the wall and not the back. That way if I need to tile something I don’t have to move the table as I will have about 4 feet behind the table in which I could set up a couple support stand to hold the end of a full sheet of plywood. I would then have access to the back at all times with no hassle and be able to reach in from the front or back to access the left side if need be since the table will only be about 50 inches deep in that direction. That sounds easier than trying to reach in 3 feet or more from the side.
If I wanted to leave it in the orientation it is now but pull it out from the wall 4 feet I don’t have enough room to do that. I also think that rotating 90 deg would help with running the power and dust collection hose.
Edit: I guess this post needs a photo.
