Found this screw on the middle of the wasteboard after a cut, not sure where it came off?
Hard to tell in the pictures, but it looks like a z axis mounting screw, or the one under the z rail (very bottom of z slider)?
Let us know if you find the location.
I too found one at one time. A careful once or twice over revealed mine came from the X axis oil port (behind the Z axis area).
I now have a ‘service’ routine that I perform every 40hs of operation that includes checking loose parts as well as 1F prescribed cleaning & lubrication.
Do you have a suckit dust boot? That looks like a screw from the dust plate/insert…
Nailed it!
You are right.
