Masso G3 ATC build update - motorized dust shoe, braking motor, reconfigured tool rack, and more
I have been busy with modifications and upgrades since my last post, and thought I would share an update. This post does not have the continued milling tests and rigidity testing that I had mentioned earlier, but I will get back to those soon.
I am also sharing this information since so many have purchased an Elite series CNC, or plan to upgrade. Even though these machines will come preconfigured and ready to go, my hope is that what follows will show just some of what this controller can also do. NOTE: The 1F Team has made it very clear over time that they will only support ‘stock’ configurations, so making changes or adding the functionality described below should keep this in mind.
In no particular order, here are the things that have kept me thinking and challenged:
New Z axis motor
One thing I had noticed with my ATC spindle (and higher pitch of the z axis ball screw - I have a pre-production Z20), is that upon system shut down the spindle would slowly, and occasionally lower. It was enough that it bothered me, especially if it happened with an expensive and delicate endmill still clamped. I searched for a Nema 23 high torque stepper motor with electric brake, and finally found one on AliExpress. It works perfectly. I tied the brake into my E stop circuit which is controlled by one of my Masso relay modules, so regardless of how power is removed, the motor holds position.
More tool holders and end mills
With my old set up, I had always wanted to have more ISO20 tool holders on my tool rack at all times, but the design of my retractable tool rack cover took up room. I removed the cover (see new design in next section below) and then had room for all 14 tool holders and my tool setter as well. I now have every tool I think I will need (mostly geared for aluminum milling right now) ready for the tool changer.
The tool rack is protected by a new plexi shield which remains permanently attached to the table, and I also gained a bit more cutting area at the back.
Pendant
I decided to add a pendant, but have other ideas to use - a programmable macro keypad - but that will shown and explained in a future video. Although Masso offers one for sale, I chose to purchase my own through Amazon to save some money, but also because I did not want the DB15 connector attached. I wired mine into terminal blocks under the front of my table, and then to my Masso G3 in my enclosure - it provides even greater reach. The benefit of the Masso pendant is that it can run off the Masso PSU (it can handle up to 24+VDC), whereas mine and most others have a handwheel encoder that can run on a maximum of 5+VDC. The Masso manual and that which came with my pendant provided all needed information, but you do need to be careful - and like to solder DB15 connectors :smiley:
New chip containment methods
I need to say from the start that the next two changes/modifications are my attempts to avoid using a vacuum for chip evacuation, particularly because my main focus right now will be milling aluminum and plastics (so no fine wood dust).
Having said that, To help contain chips I am experimenting with a clear nylon ‘curtain’ that I attached to the aluminum angle of my X axis energy chain guide. I cut 2 cm strips to make it flexible, in part so that it can ride over the plexi shield and tool holders/rack during automatic tool changes. I will see how well it works when I start my milling tests. My hope is that this curtain, as well as the plexi shield, will keep the tools at the back clear from most debris (there is an air blast as part of the tool change that takes care of any left over chips). That, and the dust shoe/shield design that surrounds the end mills during milling (see last section).
Pneumatic and motorized dust shoe
I am most excited about my prototypes for a dust shoe/shield solution.
My goals were 1) to have a fully automated retractable dust shoe that would not interfere with the automatic tool change routines, 2) to make use of the options made available from the Masso software and hardware, and 3) to have a dust shoe/shield that moved in synchronization with the height of the spindle/end mill, and lastly 4) I did not want my solution to be at all attached to the spindle body.
All my prototypes were designed using F360, and made from 3D printed parts, and parts purchased from Amazon. As these are still being tested, the final designs will change as I plan to mill them from aluminum.
The design below is for the pneumatic version. It will lower to one set point, but will also retract during an automatic tool change. It raises when the Y axis block triggers a sensor upon reaching the tool change area.
Here is also a short video showing its action: https://youtu.be/eQ7X8num2Ss
I just finished and installing the motorized version. This one I am most excited about because it does the same as the pneumatic version, but also will keep the height of the dust shoe/shield moving to match the end mill. This one makes use of the same sensor, but also Masso’s ‘toggled’ auxiliary inputs/outputs.
Here is a short video showing its functionality: https://youtu.be/1HjdcC2kS5g
Did you ever end up deciding on a dust boot design you liked ?
The one I am contemplating is similar to Datron’s Clean Cut system - https://www.youtube.com/watch?app=desktop&v=KqUzgsGd9dU
I have a 3D printed initial prototype which works well with my Fein vacuum - I do not use a large diameter dust extraction system.
The challenge for all the designs is how best to incorporate it with the ATC process. I have a few ideas, but will not continue designing until I have my new Z assembly designed and installed as it will need a different method of attachment and mechanism for retraction.
The easiest solution is to use tall, pedestal like linear tool holders. However, having spent time and money recently building my new 24 tool design, I am not quite ready to abandon it.
Have you seen this design by chance? At first glance I like it a lot RoboCNC X2 Router Z-axis | My CMS
Hey Tom, hey all,
this is a very cool system.
But it also shows that a softmetal chips extractor and a wood dust extractor are different things.
Thank you for sharing the video.
I visit his site from time to time, and had seen this and his other videos when I was researching DIY CNC builds - that was before I decided to buy my Woodworker a few years back. His build, including the Z axis assembly, is most likely the route I would go should I decide to build my own. The only difference is I would choose to have moving guides not rails on the Z axis. Here is a video I found which discusses the pros and cons, and includes a nice FEA analysis of both designs, for those using F360 - https://www.youtube.com/watch?v=qjuqtvhIDlQ&t=1s
I am hoping to find a reasonable compromise in using my current set-up, as I do not plan to set up a larger ‘wood specific’ solution, at least not at this time and in my current basement location.
Although the prototype I am using is printed plastic, the plan is to use metal, as the IPA mist system I occasionally use on aluminum causes microfractures in the acrylic used in most dust shoe designs.
I am also finding as I gain more machining experience, that - as you allude to - different materials and types of machining may benefit from different methods of dust extraction.
For example, when I machine aluminum, I like to see the cutting and use air blast for chip evacuation. In this scenario I liked using one of my dust ‘shield’ designs, where I am happy to collect the chips at the end of the machining. In contrast, when switching to wood and using a surfacing bit for example, my ‘Datron like’ prototype and Fein vacuum with bag and HEPA has worked quit well in preliminary testing.
I may end up designing a modular chip evacuation/dust vacuum system, where the main mounting and retraction mechanism remain the same, but different attachments can be swapped out depending on the need.
@TMToronto Tom, very impressive build and further upgrades/improvements! Kudos on your accomplishments!
Thank you for your kind words, I appreciate it.
This has been a great hobby for me as I am able to satisfy my interests in a variety of disciplines, whether related to the continual building and modification of my CNC, or the actual machining of materials - there is always so much more to learn (and fail at). :grin:
Hey Tom, do you happen to have a link to that aliexpress Z Motor?
I believe it was this one … https://www.cloudraylaser.com/products/cloudray-143mm-3n-m-5a-2-phase-nema23-open-loop-stepper-motor
Although, it is odd the page does not mention that it has a brake, but the specs match mine. Here is a link to their product page that confirms it is the one (‘Z’ denotes brake versions). … https://cloudray.oss-us-west-1.aliyuncs.com/Catalog/Stepper%20Motors%20%26%20Drivers%20V202006.pdf
I ordered mine from AliExpress.
Thanks a lot, i’ll take a look
It has been working as expected with no issues since installation, just be aware…
  1. It draws/requires power to keep the brake unclamped - the coil stays hot
  2. It has an 8 mm shaft - you may need a new coupler
  3. It has a relatively high 3.73 mH inductance - not really a problem for me as I use a 48 VDC power and the speeds are fairly low on this axis.
None of these were deal breakers for me, and were understood ahead of purchase.
How could I go about checking to make sure i have those bases covered in my end beforehand?
I built my own electronics for my Woodworker based on a Masso G3, so your wiring may be different if using a Masso Touch or BB controller. You would need to provide 24 VDC to run the brake, and a way to control it. I am controlling it via a relay that is part of my E stop safety circuit.
The Z20 ballscrew shaft end is 8 mm OD, but I believe the Onefinity motor shafts are 1/4" OD - I used my own motors that have a 3/8" shaft. You would need a coupler that connects 8 mm to whatever the ballscrew shaft diameter of your Z axis assembly is.
The motor inductance is not really an issue - best practice tries to keep the inductance as low as possible for best performance. Higher inductance motors will benefit from being powered by a higher voltage PSU.
Awesome, thank you very much
Hey @TMToronto this is great stuff! I have been following this for a while and decided to try my hand at the pendant. I got the one I think it was you or someone you were interacting with in another thread off of Amazon and have it wired completely with one exception, the black wire from the pendant that says “DB-15 Body”. I have no idea what to do with this one. The axis & resolution seems to be wired correctly as the indicate properly on the F1 screen but the dial does nothing. If you or anyone could please let me know where the black wire for the pendant should be connected to the maso I would greatly appreciate it!
Dave
Here is a discussion in the Masso forum where I shared details of my wiring in order to help someone gets their 3rd party pendant working.
https://forums.masso.com.au/threads/pendant-wiring-pinout.3448/
The black wire on my particular pendant connects to -VDC. In the electronics enclosure I built, I use terminal blocks to connect all the -VDC together - a star configuration. This is where I have the black pendant wire terminated. For the red +VDC wire, I have that connected to a 5V power supply.
Geezum, yeah that makes sense! I will try that and really appreciate the other thread and reply!
Dave
Happy to help.
I would just double check that your particular pendant’s wiring matches mine.
Hopefully your follow-up be one where all is working as expected.
