My first experiments with Corian
I had read how you could use Corian to create lithophanes so I thought I’d give it a try. I got some free scraps from a kitchen counter company. The first thing I discovered was that not all Corian is semi-transparent, so lot of my free samples could not be used for a lithophane. The next thing I discovered was that most people don’t want a plain white countertop, so the materials that were semi-translucent had speckles or wavy swirls in them. The speckles and swirls ended up showing up in the lithophane.
After the lithophane exercise I decided to try making something else from my stash of free Corian. Ended up doing an epoxy inlay to make a light switch cover for my daughter who has a thing for penguins. I was quite pleased with how well this turned out.
What settings did you use if you don’t mind me asking? Does it cut just like a hard wood or more like plastic?
For the light switch cover I used the following:
Inlays:
1/8" end mill
22,000 rpm
30"/min travel
20" plunge rate
.1" max depth
.06" pass depth
Surface after epoxy:
1/4" end mill
19,000 rpm
60"/min travel
.02 max depth
Cutout rectangle:
1/4" end mill
19,000 rpm
40"/min travel
.1" pass depth
For the litho I did the following:
The material was too thick for a litho so I first created a pocket using a 45 deg chamfer around the edge, sort of like a picture frame, then I cleared the pocket. After that I cut the litho and finished by cutting out the outside perimeter of the frame.
Pocket chamfer:
90deg V bit
50"/min travel
17,000 rpm
0.19" max depth
0.1" pass depth
Clear pocket:
1/4" end mill
60"/min travel
19,000 rpm
0.19" max depth
0.1" pass depth
Photo V-Carve
60 deg, 3 flute V bit
19,000 rpm
150"/min travel
.356" max cutting depth
Cutout:
1/4" end mill
60" min travel
19,000 rpm
0.495" max depth
0.1" pass depth
Your cutting depths on the litho would change if you had a different material thickness.
Nice job. Did you do a 2 sided project for the switch cover & recess out the back like commercial plates have?
Yes, it was two sided. But there is still a minor issue with the mounting screws not being long enough depending on whether or not the switch is installed flush with the wall or if it’s recessed a little bit. But that is an easy fix to get slightly longer screws.
I’ve used it quite a bit for glue up jigs for wood working and it works really well for that. Wood glue doesn’t stick to the slick side.
Most solid surface shops willingly give away the sink drops or sell them pretty cheap.
I’m fairly new to the 1F thing so I’m trying to get it all lined out but will start doing some corian soon.
I’ve also tried it on a wood lathe and it cuts, but it cuts like a hard plastic. Tools need to be sharp for sure.
It cuts well with a 60t blade on a table saw. PPE and dust collection is a must…
