best to only move the workpiece one time. VCarve will generate the carve in the order you place the bits in the bit selection box for that toolpath, if you want to share the project you can send it to me and I can make a short video going into a little bit more detail with your exact file in front of me, it tends to make a lot more sense with the same file instead of hypotheticals. CNCSeth@gmail and If you send it I will also post the video over here in case anybody else has same question and is following the post
