Pause button graphic bug workaround
Hey @sjandrews!
Saw 1F Support answered your question and locked the thread prematurely.
The pause function still exists, but the button doesn’t. We just need to make our own temporary “button.”
In a new browser tab, enter:
xxx.xxx.xxx.xxx/api/pause
replacing the xes with your machine’s IP address.
When you hit enter in the navigation bar, it will send a request to the pause endpoint usually activated by - you know - the pause button.
If you bookmark that endpoint - BAM - temporary pause button.
Hope this helps; holler if you need a hand.
Actually the function is still there with the interface. I can press the run button to pause the cut, then press the run button again to resume. the confusion was not having the graphic change.
Ha! I feel sheepish!
It never occured to me to press the Run button to pause…
Thank you for posting this. I’m new to Onefinity machines and I didn’t know they had a pause function hidden within the RUN button!
Mike
