I just searched for Inventor in Buildbotics – no results. Thanks for the idea tho.
So I tried using the Fusion post processor file (.cps) with Inventor, and it seems to work… mostly. I designed a simple part with 2D tool paths only, and I air-cut it first and then a piece of pine. It’s dimensionally accurate. One thing that startled me was when I pushed “play” the dialog that asks you if you turned on the router didn’t come up. I’ve grown fond of that warning – Onefinity: is there a gcode command that will produce the dialog?
Also when done, the router returned to home and not zero.
Thanks!
