The Onefinity Gen 2 Elite machine can be used in all countries. Onefinity will send out the proper power supply and power cord automatically for your select country. There is no need to contact us.
If you live in an area that uses 110v (like US and Canada), Onefinity will ship you a 110v power supply.
If you live in an area that uses 220v standard (like Europe and Australia), Onefinity will ship you a 220v power supply.
110v
110V version (USA/CANADA/Etc.):
Requires a 15amp (breaker) for the machine and controller. -
Vacuums/Dust collections should be on it’s own at least 15amp (20amp is ideal) breaker line. This is suggested to reduce potential EMI that can cause the machine to not operate correctly. See: EMI | Screen Flickering, Blank, or Black Screen, Randomly Loosing Zeros, Freezing, Disconnecting or Random Happenings
A VFD/Spindle must always be plugged in directly to wall power. It will require it’s own breaker (making a total of 3 breakers) at whatever specs the VFD/Spindle manufacturer recommends.
220v
220V Version (UK/EU/AUSTRALIA/Etc.)
Requires a 20amp (breaker) for the machine and controller. -
