PwnCNC VFD Settings on OneFinity Masso
I bought a spindle kit from PwnCNC back a few months ago and they sent it and the cable ready to connect to an AltMill via the Modbus connection. I used it on my Openbuilds unit with a Sienci Super Longboard Controller and it worked flawlessly.
I changed my mind about buying the AltMill and bought a OneFinity Journeyman Elite with the Masso controller. I bought the dual female GX12 6 pin cable and connected to the PWN port on the VFD and the bottom of the Masso unit. After entering the correct values in the Masso spindle setup section when I enter an RPM up to 24000 and choose “run” I get values in the VFD display from 0 to 10 but no movement in the spindle.
I am thinking this is a simple fix of changing some entries in the VFD since it was initially setup for another machine. Rather than poking around and chance making things worse I thought I would post a message to see if anyone can let me know if this is the case and what entry or entries that I need to change in the VFD to make it work with the Masso.
Have you set the switch to automatic instead of manual?
