Question for support
What are the pros and cons of using the redline dedicated computer vs the software on a pc ?
I have ran grbl software in the past with no iseues does the redline software run smoothly and reliably?
Timeline on Mac RealTime CNC Sender?
Thanks,
Karl
How about Linux ? Ditch windows and Mac lol
Also is this real time cnc sender the same as the redline screen or different ?
Exactly the same. Realtime is the software that powers the controller.
Will you be offering an upgrade kit that uses a computer instead of the touchscreen?
I’ve been doing some digging and this seems do-able from a technical standpoint. Seems like Redline’s controller is actually a RealTime CNC RTS-X controller. The RTS-X controller is available in both closed loop (elite series) and open loop (BB version) as seen here - Home - RealTime CNC Documenation Hub . If you look here Software - RealTime CNC Documenation Hub their software UI matches the Redline UI, and further down the page you’ll see their software can run on a raspberry Pi, they even provide the image for it. Here https://realtimecnc.com they note they have partnered with Redline and Onefinity for distribution, Furthermore, if you look here Product Specs - RealTime CNC they note their software (the UI, etc.) can run on Windows, MAC and Linux (Raspberry Pi). This is super awesome!
I believe what this all means is that with an updated Redlline/RealTime CNC RTS-X standalone controller (hardware) it may be possible to just re-flash the Raspberry Pi in the BB controller to run the UI software, or if you prefer simply use a PC/MAC to run the software for more power. The heavy lifting appears to be done by the controller itself though.
Anyhow, I think that’s what all that means. Of course I could be completely wrong ![]()
The Redline controller seems to run on a Raspberry Pi 5 which is way faster than what’s probably in the Buildbotics… So while it could (should) work, the experience would probably be bad. I did test the image provided by RealTime CNC on a Raspberry Pi 3B (offline mode since I do not have the Redline controller - yet) and it does work but it is quite slow, especially navigating the 3D rendering of gcode.
Which model how much ram on it ? The pi
Does it have a power supply or running off the pc ?
Lots of factors that can cause that , I have a bunch of Lenovo think clients I will Be using one with a touch screen
To add to the conversation, just for giggles I burned three days last week configuring a RasberryPI 5 to work with a $100 touch screen from the RTCNC image. 8GB of RAM with both a 64GB SD card and, just for fun also installed on a 256GB M.2 SSD drive, which surprisingly didn’t boot much faster than the modern SD card, though you want to use a modern SD card, the older one I first tested w/was slow as moles-asses.
It appears that the UI/UX software is running on python, so I’m guessing that should account for cross system portability. Since the PI runs on Debian linux, I can’t imagine you won’t be able to run the front end on any flavor of linux you like, though I imagine that might be a choose your own adventure setup. From a systems perspective, it’s sometimes best to limit how many different configurations you have to support.
All that being said, I received my batch 2 Redline Elite last week and have unboxed the Redline Controller and it’s an absolutely gorgeous beast of an enclosure. It has a self contained power supply to drive, what I’m pretty sure is a Pi 5 and touchscreen, but just damn, it’s this big beautiful chunk of milled black anodized aluminum. I wouldn’t want to drop it on the screen, but boy that enclosure sure looks like it’ll last a lifetime.
I may continue to tinker with the idea of a bring your own touchscreen solution, but more for the adventure than any real world $$$ savings. I have a vision of 15” touch screen in a walnut case milled on the Onefinity, with brass steam punk accents. I have no idea where this idea sprang from, though likely it was the bourbon…
If I had to do it over again, I’d do it the same thing and buy the UI/UX touchscreen from Redline, and you can use my discount social influencer code…. nah, just kidding, I have no affiliation with RL, 1F, or RTCNC, just my general observations of the sheer build quality of the enclosure probably being worth it.
Jury’s still out on software, as I have to still setup the machine and get things configured, but it seems like RTCNC is working hard at sorting issues as the rollout and development continues.
Did you install it? Did you have the chance to test the responsiveness of the jogging buttons?
No, I haven’t played with in the real world.
I’m still working on assembling the machine and will probably familiarize myself with the RL controller before I ever try hooking up my home brew, which honestly was just a cludge of screen HDMI cables, power bricks and a Pi 5 sitting on my desk.
Unless there’s an issue with the responsiveness of the touch screen itself, I imagine it will be similar to the kit Redline put together.
I meant the responsiveness of the Redline HMI itself… I know gSender (Sienci labs) is not very responsive and I am wondering if Redline HMI is better
Take a look at this video https://www.youtube.com/watch?v=GzTPMHOK7oY
