I am venturing off into cutting metals on my 1F Foreman, with the stiffy option. While I am a Mech Engr., I am not a Machinist. So the Machinists out there bash away
I have a 3 HP (2.2 Kw) ISO-30 spindle, mounted to the Z gantry via an aluminum plate.
The machine is mounted to a ¾ in ply torsion box that sits on a 2x6 wooden frame. The table has a sandbox with brake rotors and sand to help dampen vibrations.
Hopefully I achieve a reasonable level of stiffness and vibration control.
My compressed air runs through a Frankenstein air cooler/ dryer.
I have added a simple air blast system that is manually turned on/off. It runs at 30 psi. This hopefully does two things:
- removes chips so they are not re-cut
- helps keep the stock cool.
To also aid in keeping the stock cool I spread a thin layer of “tap magic” cutting fluid on top of the stock. I don’t want to mist because of the MDF.
All of my jigs/holders are ¾” MDF. It is cheap and disposable. I have “reserved” the front right portion of my machine for metal work. To isolate the space I have this:
The brush seals sit in a custom 3D printed holder. Just trying to keep the chips corralled.
Currently I am making brass name plates.
My machining holding system is based COMPLETELY of of machine coordinates. By that I mean I am setting G54 off of machine coordinates not a touch off… Ok Z is still a touch off.
To create the bottom plate I screw down the MDF, set G54 and cut out a pocket of 0.92” this is my stock thickness. The size of the MDF has to be close as in .25” but letting the machine cut the pocket insures it is correct.
To mount the stock I use the super glue and tape method, aligning the stock to the left hand side of the pocket. I also align the bottom of the stock to the bottom of the jig with ~1/64 overhang, any extra stock is machined away. Better to waste a bit than to come up short.
I then knowing where the stock run my cut out program. Part number two uses the same program AFTER I reset G54s Y to a new value. Rinse and repeat… making sure the part is cool to the touch. Melting tape is not a good thing.
This has my blanks cut. To actually engrave I made a secondary stock holder I again I used MDF and pocketed in the name plate.
The trick here to get repeatable positioning of the jig holder. To accomplish this I use .25 dowel pins. I machined .25 inch holes in the top of my base jig and then .25 inch holes in the bottom of my nameplate jig. Putting the dowels into base jig then the name jig registers correctly. Notice I said dowel pins and not gage pins … I have a few gage pins but those guys are expensive (I lose things) and dowels are close enough.
A question was also about bit selection. For this job I am using Lakeshore Carbide’s, they had been recommended by a few folks.
1/8" CARBIDE STUB END MILL AlTiN COATED 2 FLUTE ($8), I went with a stub mill because they:
- Cheap … learning I may break them
- My stock is 0.092 thick PLENTY of cut length
- Consistent diameter and short shank
20 DEG PER SIDE TAPERED ENGRAVER, .020 DIA BALL, 2 FL HP-HLX, 1/4 SHANK (Double ended ~$23)
- Pure and simple recommended by John Saunders of NYC CNC, Saunders Machine Works and Business of Machining Podcast
So there you have it, my set up for thin metals.
For thicker stock I would likely go with a SMW fixture plate and their Mod Vices, but hard to justify those now.
So my machinist friends out there, what can I do to improve? Where am I being stupid?![]()
