Redline VFD desktop clamps
A recent post by Robert/ HardtailSr pointed out the lack of a way to secure the VFD desktop mount. He suggested that that a 3d printed solution would be appropriate. My VFD is on a wall mount so I ordered up a desktop version and began modeling in Shapr3d. After numerous iterations this is what I came up with. They hold the mount very securely and increase its footprint minimally. I’m pleased with the results.
I’m offering these at $20 ,including shipping. I’m also offering the file if you want to print your own at $5. You can contact me at fro608@gmail.com if interested.
Thanks !
I like it. My recommendation would be to remove/ reduce the taller inner portion of the inside lip as to not block the vent as much (red) but keep a couple tabs in the corners (green) to keep it locked into place.
there is plenty of ventilation small tabs are easily broken. keep it the way it is lol
Tabs would not break. Only if you’re pushing or putting tons of force on the VFD, which you shouldn’t be doing. Keeping as much air flow, which is how the mount is designed would be better.
I’ll play around with that and see what I can come up with. Thanks for your input.
How about something like this? My printer is busy, I’ll get one printed up this afternoon.
Good job. Looks great.
Personally I like the first iteration. Seems like a stiffer more robust design with adequate venting.
I’ll be able to judge the strength of the modified version once I get a couple printed. I think I’ll be ok, it would probably take a pretty good whack to bust it loose.
Exactly what I was thinking. That’s perfect!
If maximizing airflow is the goal you could keep the thicker sides if you design it to stand off the table a bit to allow airflow below the VFD.
Nevermind. The mount is already doing that. I should probably refrain from commenting on such things while my machine is still in boxes :slight_smile:
no i think that is a good point. but i think we are all over thinking this a bit lol
Here’s the revised, “enhanced airflow” version. I don’t think I’ve sacrificed much in terms of holding strength, it’s really on there. If you hit your VFD hard enough to break it loose you will probably break something on the VFD first!
Also, this pared off about 10 minutes of print time which is a plus.
I’ll definitely be ordering a set from you. Nice work!
very nicely done and thank you good collaboration :slight_smile:
