New at cnc. 1st G code program ITried to run ,get message estop not found. What am I doing wrong.
Does it do this when you are trying to probe for X,Y & Z? If so you need to be closer to the touch probe plate. You need to centre your bit over the circle on the probe block approx 1/4" (6.35mm) above it.
