Thanks for the reply I think you have a great product
3D Files Download
The 3D files are linked below. My apologies for not being able to credit the original creator, as I likely found these through a lengthy search on Thingiverse, but they may have come from the Printables website as well.
Material and Print Recommendations
For this project, I used standard PLA. If you’re uncertain whether your PLA settings will provide the necessary flexibility for inserting and removing the hose, I highly recommend using PETG. The only reason PLA worked for me is due to using a minimum of 2 perimeters and grid infill. Without that, the part wouldn’t flex enough. And, even with these settings, the PLA still isn’t technically flexible enough for the rigid 4" to 2" hose adapter to easily fit through. Instead, I pull the adapter forward until it pops out, then lift up on the more flexible hose which will pass through the clamp.
Print Settings
I don’t have the exact settings used for this print, but I likely relied on my standard settings in PrusaSlicer (see screenshots below). These include a nozzle temperature of 210°C, a bed temperature of 70°C, and 100% cooling throughout. Note that these settings are for my heavily modified Ender 5 Plus, which has been converted to linear rails and equipped with a Micro-Swiss extruder and hot end.
3D STL Model File:
https://drive.google.com/file/d/149RF0Mzre5w4aq5sHqQ5Qnb3D0q5eDqI/view?usp=sharing
Fusion 360 File:
https://drive.google.com/file/d/1lJP_zoH_y7Jc3XMCVM4-o-Exrhxfgxvl/view?usp=sharing
3D STEP File:
https://drive.google.com/file/d/1OeXpn6pqRKB1ASCFwN0rTdaUY7NU9x_-/view?usp=sharing
Hey everyone,
I’m temporarily pausing the sale of Hermes for a bit while I resolve some administrative issues. All models will be out of stock for the time being.
I’m sorry, and thank you for your patience!
Josh
Alright, we’re back. Administrative issues have been averted.
Currently available:
Z20 80mm mount 80mm spindle
Z20 80mm mount adapted for 65mm spindle
Z16 80mm mount 80mm spindle
Z16 80mm mount adapted for 65mm spindle
Being tested:
Z16 65mm mount 65mm spindle
On the backburner:
Z20 65mm mount 65mm spindle
Are there plans to offer a fully assembled dust boot for people that do not have a 3D printer?
Perhaps eventually, but not anytime soon. Sorry.
There are online services that you can send files to and have them 3D print the item. You may want to look into that as an option. I don’t know how costly it is.
I have a question about the magnets. You specify the size but not the strength. N35 are very common and cheap, is that what you use? N52 are a little more expensive but also stronger, would they be a benefit or a problem? I.e Can they be too strong? Or could you use fewer given they are stronger?
Also a question about the back light. Looks like you are relying on transparent PETG and just shining a light through from the back that is then transmitted through the transparent mount. I kinda prefer the look of a matte black, is there some method where a light can be inserted in to the mount instead of shining through it?
What are you using for a light?
Thanks.
Hey Atroz,
The magnets I use are unrated, cheap 6mm x 3mm neodymium from Amazon. I found that on the metric of pull force per dollar, it made more sense to use 16 weaker magnets than say 8 N52 magnets from a dedicated magnet supplier. More magnets means more available snap positions, even when using alternating polarity (for a genderless connection). You’re welcome to use whatever strength you feel is right, and you don’t need to follow the spec if you don’t want to. You can definitely use whatever number you want, at whatever strength you want. But since you can get 200 6mm x 3mm for about $13 shipped, I figured that would lower the barrier of entry for most people, especially if they already have old Suckit hardware.
And honestly, I rarely detach my hose or view portal from the shoe, so if you want to just forget using magnets altogether and glue it solid with 6mm x 6mm pegs, that’s an option (not recommended, though, and there may be other accessories in the future that you’ll miss out on).
The spindle fits pretty tight against the Hermes, which helps it maintain a good vacuum seal. There’s little to no space inside the mount for a light. It’s much simpler to print it out of clear PETG and mount the backlight to the bottom of the X carriage (which also enables permanent wiring that isn’t affected by the height of the Hermes).
My backlight is nothing special, just a keychain emergency light that I had lying around.
I strongly recommend clear PETG if you plan on using the view portal (which is optional, but very cool). Even just ambient light will provide enough to see the bit. Recently I’ve taken to just using my 20V Dewalt flashlight and hitting the side of the Hermes to really get a good view. I’ll work out a permanent solution eventually, but it’s a low priority.
OK, thanks. I think I will go with the clear PETG. Function over looks. Will do the view portal too. I have an enclosure over my machine with some good lighting from the sides and back, it may be enough to penetrate through the boot without an additional light. I have multiple spools of PETG but none of it is transparent, guess I’ll have to order some.
BTW, you could make up for the airflow with just another inlet. A 2.5" hose would move less than 1/2 the air of a 4" but if you were to put a Y adapter in and have 2X 2.5" you’d be getting close. Not sure what the second one would be used for except vacuuming the air, but it would keep the airflow up and your dust collection motor cooler.
Another question. What did you use to cut the acrylic tube? They’re quite expensive and Acrylic is prone to cracking when cutting so I don’t want to mess this up. With ABS I’d just use my siding mitre saw, but I’m hesitant to try that with the Acrylic.
Thanks.
I used a Dewalt miter saw with a 60 tooth blade. Go slow, it cuts nicely.
Yes, like Scott said, just go slow on a miter saw, it worked fine. You may have a bit of a melted burr that is easy to file away.
Ok, thanks guys. I give it a try after the acrylic arrives.
Tube cut, went very well. Fit to printed part looks good too.
When is this going to be available?
Hey Rob,
It’s available now!
Hermes Dust Boot Maker Files - Workman Design and Manufacturing
Please be aware that the spindle version will not work well with the Makita router.
Josh
I am looking for the Makita option, that’s what I have now. When will that be ready?
Would this be printable on a Bambu labs X1Carbon?
