Would you use a common round nose bit for a wave texture? Or would you use a ball nosed bit? Or either would work as long as VCarve knows which bit you’re using to cut a wavy texture?
You can program Vcarve to do whatever you like… then you can put another/ different bit in the spindle… the spindle doesn’t know…
For example, I program a 60 degree bit in Vcarve, and use a 30 degree bit in the spindle… the result is different but exactly what I want…
Best to do a test run before you do the real thing…
Lots of test runs on their computer and then the scrap MDF. I’m new but am learning that pretty quickly. Thanks Bear.
Cool half-tone type stuff! Yeah, I like! I’m hoping to do some screen print/mezzo print stuff after I understand how to make my half-time maps. Being a graphic design guy in print, I actually kind of remember how cool that type of stuff is… Looking good Bear!
