What mount is necessary for the Redline 80mm spindle?
I have a Elite Fourman with the mount necessary to mount a Makita router. I’ve just purchased the 80mm 110v spindle kit. Should I also buy this Spindle mount? https://www.onefinitycnc.com/product-page/80mm-spindle-mount-for-z20-elite-series
Yes. An 80mm spindle won’t fit in the router mount.
either a z-16 z slider 80mm mount or a z-20 z slider with 80mm mount.
A 80mm circle will not fit in a 65mm circle, so the mount and the spindle body diameter need to match.
I haven’t seen this addressed lately and apologize if it has been.
I seem to remember reading that there is a stronger braking motor offered for the Z-20 80mm if you install a spindle. Is this different motor needed if the Redline spindle is installed?
Thanks,
Pony
I should add that this is an X series question.
Pony
