Z=0 for 3d model
A bas relief set into a pocket used three bits: 1/8” upcut, 1/16” ball nose and 1/32” ball nose. Using VCarve Pro:
-Pocket depth 0.1875, model height 0.1825 and depth ABOVE the model = 0.005.
  • Roughing bit Machining Allowance = 0.0
  • “Rest Machining” minimum detail = 0.001
On the first try, the ball nose bits didn’t clean up the cut lines of the roughing bit. The Z=0 was set (for each bit) with the aluminum block made for that purpose.
On the next try, after setting the second bit with that block, I used the ‘paper’ method to confirm the same Z=0; but the methods didn’t agree. When the bit touched the wood (preventing movement of a bit of paper) the controller said the bit was at 0.014. In other words, it said Z=0 was that distance BELOW the surface of the material. Again, the second bit didn’t clean up marks from the first.
On the third try, I deliberately set the second bit 0.017 below the surface and told the controller that this is the real Z=0. The smoothing bit did a better job, but still not perfect. I feared it would cut into the bottom of the pocket at the model edge (but it didn’t).
  1. Why does the aluminum block (for setting depth) differ from the ‘paper’ method by so much?
2. Which setting should I change: Machining allowance? Rest Machine detail?
3. Would a down-cut spiral do any better for this than an upcut?
Measure your block and make sure that the measurements are the same in the controller. Mine were off quite a bit and my block wasn’t perfectly flat, so I surfaced it and entered those numbers.
Thank you. To paraphrase with candor, you suspect that the block is defective, as was one you have.
I can’t resurface a block to a tolerance of 0.014”. The necessity for doing so with a Onefinity-supplied device is disappointing.
I took mine to a local machine shop they didn’t even charge me flat to within .0005 (5 tenths) now. They only took a skim of a few thou off. Before I got a different measurement depending on where on the block I was measuring, now I get the same result within .001 (one thou) every time. No matter where I measure.
