Z Slider vertical location question
I was able to get onto the first batch of the introductory special for the Redline Controller and Spindle. I got the 80 mm 2.2kw spindle. When I assembled the machine I wasn’t 100% sure how high vertically to mount the Z-Slider so I just mounted fairly low. The bottom of the Z-Slider was about 4” up from the spoil board.
I only did a test cut (one of the ones pre-installed on the controller) which cut fine. I need to surface the spoil board yet but need to Tram the machine. I got one of those upside down “T” 2 dial gauge units. While just messing around with seeing how to setup the gauges I found out I wouldn’t be able to rotate the “T” with the gauges because it would hit the bottom of the Z-Slider.
So I decided to raise the Z-slider up and bolting it using the bottom hole on the slider. This gives me ~6.5 distance from the bottom of the slider to the spoil board. Plus I am end up with a 4th axis.
I also have the Stiffy too. But the issue I have is now with clamping the stepper motor and spindle cable with the “X” limit flag the cable for the stepper motor is kind of strained now. Since there is a connector on the cable that hits the side of the clamp and will not allow me to give a little more slack. It will work but I am afraid it will cause a failure of the cable after awhile.
So my question is how high do some of you mount the Z-Slider? Obviously I could move it down 1 set of mounting holes but was just curious where other users mount theirs.
Thank you
It really depends on what kind of work you do and do you have an ATC of any kind or a 4 axis machine as well. you have to have clearance for all of those. Set your height according to those needs. I have all of those things so i had to set mine pretty height in order to have working room for them.
That cable is tight if you mount it in the slot under the Z axis top cap that also routes the spindle cable. When I initially installed mine I separated the cable and ran it above the plate instead of through the slot/channel. That relieved the strain.
When I moved my Rowdy Roman hose boom over I got a new Z axis cap cover as part of the boom attachment to the Z axis and his slot was better designed and allows both cables to run under the cap without strain.
Thank you all for your replies. I may either drop the slider down 1 hole, or in the meantime take the cable out from under the clamp. I do have a 3D printer and might make something for it.
