1F Journeyman losing it's x-axis
Hey Kendell,
  1. did you adjust the currents of motor 0 for vertical use?
  2. Have you retrofit strain relief on the cables that go into the X axis, or a serious cable management system with drag chains? If not, you could check if this happened to you.
