So my fat head bumped the E-stop while I was attempting the 1.1.1 update. Now after turning it on I get a “Failed to start load kernel modules” and after that the screen goes blank. Any ideas on how to fix?
If the controller won’t boot, you may need to reflash the SD card.
There are times when you may have a file go corrupt or (advanced) users start poking under the hood and may need to reflash the entire vanilla image to the sd card. This process is essentially reinstalling the Onefinity operating system from scratch.
This process is only for advanced users OR if you were directed to this via support.
If you are looking to update the firmware from a controller that is working properly, do not use this method, look for the update file in the ‘firmware updates’ s…
Thank you, this helped and I’m back up and running.
