Downgrade my Update
How can I return to a previous update? Is it possible?
Thanks
Morning Philip,
Yes you most certainly can roll back your Firmware, this post explains exactly how to do it.
-Alex
Hello Alex,
Thanks for the info. I didn’t reflash because I believe my controller is working correctly and it won’t fix my problem. Maybe you can help me. I’m having issues with the X-axis. There is hardly any torque applied to the ball screw to make it go left or right when carving, I can push it with my little finger left or right with little resistance. I checked the washer to make sure the 17 mm nut is just right so the washer just is able to move. I made sure the ball screw was connected to the stepper motor and the grub screws were tight. Then I adjusted the X motors amp stall amps, I went all the way to 4, and still no luck. If you have any suggestions I’m all ears. I’ll call Onefinity tomorrow hopefully they can help. Thanks for your help.
Calling onefinity will do no good as all tech support is done via email only: support@onefinitycnc.com
Start here: Troubleshooting: Rail is getting hung, stuck, or out of alignment
