Add Tool numbers into the Masso
when adding tool numbers for tappered ball nose bit for tool diameter what size you put tip size shank size or does it matter much
Thanks Rob
The tool number in Masso has nothing to do with the tool dimensions. It allows Masso to tell you to change the tool and what tool to change to. It is important that the tool number and description in your CAM software match what is in Masso.
Thank you for your time
