Any experience with DuraGuard for outside signage?
I am looking to use:
https://www.roseburg.com/softwood-plywood/mdo/duragard-premium-mdo/
to create an outdoor sign. It will be relief carved with .2" high letters.
Any thoughts or recommendations? I am open to other materials.
Maybe just me but using fall-apart-icle board for outdoor might not be a great idea
Product documentation says it is OK for outside applications. If it were regular MDF, heck no!
Actually I believe it is external plywood, with a layer of hardwood, and finally a of external resin. They claim that exterior signs is an “encouraged” way of using the product.
If not this material then what?
-Carl
MDO plywood is what sign companies use for outdoor signs. DuraGuard information says it is MDO plywood.
I just did a test V carve in MDO last night. Outside perimeter cuts great with a down cut bit but V carving with a 60 degree bit leaves significant fuzz on the paper top layer as I was expecting.
40 IPM and I played with the speed from #1 to #5 and didn’t not notice much difference in fuzziness. I had painted the top surface prior to carving but doubt that caused fuzzing.
I will keep playing around with MDO to try to find a good recipe.
In the mean time, does anyone know if any manufacturers make a shear cut V bit? Also, does anyone have a source for 1/4” shank bits with a 2” flute length?
Regards
