Best bit for detailed cuts
I’m constantly asked if I can make cutouts with details that a laser cutter/engraver can do. Is there a bit (1/16th” size) that is sturdy & long enough to cut details through 1/2” thick material?
The 1/8” bit gets close, but not close enough. V bits are great for carves, but not for profile cuts.
I use a 1.5mm, 1mm ans sometimes 0.8mm cutters for very fine work
just need to be patient and take it slow
Would love to see pictures of some of this detailed work - sounds amazing.
IMG_3270
Thank you - they look great.
Thank you for this! Where do you buy these bits & what feeds/speeds do you use?
I’m in the uk and get a pack of 5 for approx $25.
I cant remember the feeds but I run the spindle at 18000 and take approx 1xdia depth of cut and haven’t broken one yet
Hope that helps
