Hello all. I am getting the small depth marks in the lettering - the N and V are most pronounced. Anyone see this before and have ideas on getting rid of it? Thanks for you thoughts.
It would appear those areas are ‘wider’ in that the bit fits between the lines so whatever you’re using to generate your g-code is driving the bit lower. See if you have the option to limit the bottom height of the cut in whatever application you are using to generate your g-code.
Thanks Derek …I will research
