Break in Gcode failure
The Elite Series with @Redlinecnc Controller tried to load the break-in gcode and getting 2 alerts. After selecting the break in gcode downloaded from Redline site and then selecting Open I get the 2 alerts.
The first says
Error: unknown error
Line 1: m3 s6000 g4 p1200
I dismiss the alert and the second alert which was underneath the first one says:
Unsupported G command: G4
Line1: m3 s6000 g4 p1200
I edited the file and changed all the lowercase to uppercase and still get same error.
Also, getting error G54 unsupported on another macro file. According to Supported Codes - RealTime CNC Documenation Hub G54 is supported.
Right now trying the break in manually using MDI which does work after Homing but fiddling with files casues MDI to stop responding and have to rehome again. I sincerely wish they would open source the code so I can fix some things and see what is going on. Huge mistake in not letting community help out.
The current version (1.1.0) of the redline firmware doesn’t support dwell values.
There is an internal beta software that enables dwell so this will be resolved in the next firmware.
This is not an open sourced product.
It was also an ‘early adopter promo’, that was clear that purchasers would be the first users of the product and to expect some bumps and bugs along the way.
No problem with the bumps, I am a retired firmware engineer. Just wish I could dive in and help. Will pull out the G4’s and try again although the Redline source gcode for breakin and warm up should have already done this IMHO.
