Break in and warmup files
I set my machine up, then was out of the country for 3 weeks, it killed me to leave!
Anyways, downloaded the breakin and warmup files from Onefinity. I get these error messages, one on top of the other when trying to run them.
No need to run the break in via code! The redline controller, with firmware 1.1.1 added the ‘bacon’ button. It does it automatically!
See: Downloads - RealTime CNC
You are on 1.1.0, which didn’t have support for DWELL. 1.1.1 adds support :slight_smile:
Awesome, just downloaded and installed it. When I run it, Stage 1 says 6,000 RPM for 10 minutes, but the countdown clock is counting down, but the spindle doesn’t run. It says Warming Up: Stage 1, but doesn’t spin.
Is your VFD powered on, and do you have it enable in the spindle section of the flyout menu?
The VFD is powered on, am not sure what you mean by enabled, newbie here. I did put 18,000 in the target RPM and restarted the warm up cycle and it’s running now. Ran 6000 RPM for 10 minutes, just ramped up to 12000.
Awesome! Glad it’s running!
