I didn’t have a manual for the redline spindle and I installed mine off a video online. I missed completely that I needed to break it in. I’ve been running it for a days, should I still break it in or did I screw that up bad enough that there’s no point now? It’s run for at least 5 hours now. Appreciate any advice on this, hope I didn’t screw anything up!
Hi Cameron,
Here’s where all the manuals are: https://www.onefinitycnc.com/support
We would still recommend running the break in, and then the warm up.
Ok, I’ll run it on the morning, appreciate the response!
Also, if you have the redline enabled in the settings a cool feature would be to have a warm up button with the daily warmup routine programmed in show up on the screen. Might be a good feature for a later update.
You can put the warmup program that is in the manual on your usb and then set the Masso to run it on startup. The option is in the F1 menu.
Or, you can set up an ‘easy button’ and assign the program to that.
