Spindle doesn’t run (power on vfd before powering up redline controller)
Im setting up my Onefinity, playing around with some files for the wasteboard. It ran just fine this afternoon, came out to the shop tonight and won’t run a file. Ive tried a number of files I’ve run before as well. Machine state says Spindle Wait.
If I run a file, it jumps to line 11, and a message pops up says, Current line 11 is not the start of the file. This feature is experimental. Are you sure you want to start at this time?
If I click Yes it doesn’t do anything anyways.
I’ve turned the machine off and on with no change.
The Elite Series with @Redlinecnc Controller
Spindle error is covered in the manual. Essentually, turn your vfd on.
Hit Rewind before hitting play, because your file got stuck last time you hit play and it’s trying to resume from where it got stuck when it expected the spindle to spin up but didn’t (most likely because the vfd isn’t on and the red button on the DRO (reset) button wasn’t pushed).
