Does the probe connection on the breakout board override the one in the controller or could you potentially have two probes attached to the machine? I was thinking of using the probe connection on the breakout board to wire a second probe in the front right corner to use with the bit setter macro from @BNB187 so we don’t have to keep moving the one probe.
Thoughts and/or ideas anyone?
Thanks
They can both work at the same time, they simply complete a circuit. The challenge to having 2 probes is there is only one setting in the controller for the probe thickness - if they are different thicknesses it can affect the precision of the setup if you were to use the different probes on the same project.
