Can Mach 3 or 4 be used with the Onefinity?
Mach3 and Mach 4 cannot be used by Onefinity with our stock controller. This is because it has it’s own, custom, built in motion control software.
To use Mach 3/4, you will need a different controller. This would be quite a large undertaking as you will need to then: splice your own wiring, add limit switches when the Onefinity is not design to use or mount them, and figure out motor setting for your aftermarket controller.
We realize some users may be familiar with different controllers/motion software and that’s the reason why, when going through checkout, we give the option to buy a Onefinity without our controller.
