Carbide Create G-code June 30, 2023 no longer works
Any one find a way around converting Carbide Create C2D to G-code?
I use to go to this web link Extract GCode from Carbide Create V7 and upload the C2D file and convert it.
Now I get this message NOTE: This page will be limited to use by owners of Carbide 3D machines starting on June 30, 2023. If you have any questions, please contact support. which will cost money to do so.
I have not found any other free converters for g-code.
I am in the same situation and extremely frustrated at Carbide. Maybe there is a workaround with Fusion 360.
Use Carbide Create 5 or 6. Found out the same thing today. You can design in 7 then export SVG and import it into an older version and then make the tool paths.
Thanks Dash for the recommendation. For anyone who runs in this problem you can download Carbide Create v6 at https://carbide3d.com/carbidecreate/download6.
I’m frustrated at Carbide because a service they previously offered for free is now a paid service without any notice. People make time and effort learning software with the expectation the workflow they go with will not change.
Unless GM offered free oil changes for Ford cars at one point that’s a bad analogy.
Many of us that us Carbide Create found the V6 allows you to save gCode (button) in the Toolpaths tab(without purchasing CarbidePro). Also you can save just as gCode in Carbide Motion.
Thanks. Do you know how to change the measurement units from inches to metric/mm?
MarMasSen (Marco):
Yes!
In Carbide Create V6, with nothing in your workplane selected, click the gear icon in the ‘Setup’ box. I’ve circled it in blue in the image below.
A window should pop up with things like material size, machine type, etc.
At the bottom of that there should be a dropdown box labeled ‘Units’, and it will display either ‘inch’ or ‘mm’. Click that dropdown menu, and select the option you wish to use. The arrow is pointing to the dropdown I’m referring to in this final image.
If you are using V7 or V8, the process is the same, but some icons or verbiage may be slightly different. The location of the things to click and select are the same though.
