Check out the all new "SWINGER"! A Z dependent Dust Boot By Rowdy Roman
Check out the all new “SWINGER”! A Z dependent Dust Boot By @RowdyRoman .
Who is Rowdy Roman?
Rowdy Roman is our Official 3rd party partner specializing in accessories for the Onefinity CNC including the hose boom, spindle led light, touch probe holder and more!
The Swinger
Rowdy Roman has developed a Z dependent dust boot (attaches to the router/spindle so it goes up and down with z movements, unlike our Suck it, which is Z independent and does not go up and down with Z movements) that has incredible suction, clear acrylic on top, removable brush for filming, and the game changing ‘swinging’ open feature on a hinge, which makes bit changes a breeze!
It comes in both the 65mm or 80mm size, so you can use it with a Makita router or Spindle.
What makes this dust boot so special?
1: Hinges open to allow easy access for your bit changes. No more unhooking your dust collector hose or taking off your dust boot to change bits
2: Huge window to allow for viewing what exactly is going on during your carve.
3: Comes 98% Assembled!!! (just put the brushes in and be done)
4: Detach the front brushes and still vacuum most of the dust. This thing has massive suction!!!
5: The Swinger comes with a Cam Lever to help make one handed adjustments to the height of your boot
6: 3D Printed in all ABS Filament
7: 65mm option comes with 1.5" Brushes and the 80mm option comes with 2" brushes
8: Multiple hose adapters available so it will work with 99% of vacuums on the market today.
You can get your own Swinger dust boot from
Rowdy Roman’s site below!
Hi, I have a swinger dust boot. I like it. I just had it fail in a humorous fashion.
I run a Makita router on a Journeyman table. The swinger installed easily. It really is a nice unit.
I was resurfacing my table. Since it is long and boring operation, I went to the room next door to work on the computer. After 15 minutes I came back to the shop. The resurfacing was still going on but the swinger part of the dust boot had come off. I stopped the resurfacing. Reassembled the dust boot. Then restarted.
About five minutes later, as the router was making a pass right in front of me, I notice the bolt that acts as the hinge for the swinger was unscrewing itself due the vibration from the router and the torque the dust collector hose was putting on the swinger. Curiously, the unscrewing only occurred on passes going across the front of the table.
I suspect that replacing the bolt with a pin will solve the problem.
--grank
