What is the best clamp for a board 14” W x 20” L x .75” D? Would Oops clamps work? Board would be hardwood. Thanks, Mark
Blockquote
Blockquote
What system are you using to hold the clamp (i.e., T-slot,…?), and what operations are you doing (i.e., facing entire top surface,…?) ?
Thanks for asking. I should have mentioned that I have t-tracks and will be carving pockets and profiles for electric guitar bodies and necks. The guitar body blank weighs 8-10 lbs.
Thanks.
Mark
I do not have much experience with larger wooden stock like yours, as I mill mostly aluminum. The wood work I have done has been 2 sided 3D carves in smaller but thicker stock. For that I have used fixing bolts through the stock, but that is onto a fixture plate with M6 threaded holes using exact locations for the bolts.
Recently I purchased a set of Tiger Claw clamps from Carbide 3D for larger flat plates of aluminum stock. I really like them as they are low profile and apply a side and downward clamping force - they hold extremely well. They use M6 screws for both the fixed and adjustable clamps. These may work for you, but you may need to check the distances from the sides of your guitar stock to the T-tracks to see how much room there is. I think the adjusting clamp only gives about 20-25 mm of adjustment. The bolts you use for your T-track system may work for these clamps if they are 1/4".
Others may have options that are more applicable to your use case.
Hey Mark,
The oops clamps work but have a limited screw length so are not the suitable for very thick blanks. On thick blanks you would use a helper block on the other end of the oops clamp.
The best clamping system is the vacuum table, because you have no clamps in the way that you could hit with your bit, but it is also the most expensive of all workholding systems. It however allows you to do things like this ![]()
If you make solid-body guitar bodies and necks, you can use this two-side method described in this video. This avoids cutting into your vacuum table.
However they show a method without vacuum table, but with a wasteboard and indexing pins, the body and neck blanks are screwed into the wasteboard.
Thanks so much for all of your suggestions. I will investigate he options you mention. Mark
Hello I think i have the perfect solution for your clamping needs strong, versatile, and ultra low profile. see them on hilljackfab.com
as you can see i use these clamps on both thick and thin materials. both for material clamping and fixtures. there really is no limit to the thickness you can clamp, and they exert pressure down and in as you set them. The clamp faces are angled as well so you can catch a very small area at almost any angle. a set of four it only 39.95 and shipping is free all this month to anywhere in the lower 48. USA made by Hilljack Fabrication right here in NC. the best part is they only rise above your material by .125 inches yep 1/8 of an inch so when your spindle or router bit travels to the next toolpath (most travel at a z height of .200) there is no way for it to hit these clamps. you can see a video review of these clamps on Mitchells Woodworks You Tube channel. here is the link. (1) Mitchells Woodwork LLC - YouTube
happy carving
These clamps will do the job. take a look at them and see them in action.
here is a new video on hilljack Fabrications ultra low profile clamps mead to fit both QCW T Tracks and standard T tracks. take a look I think you will like what you see.
(49) Hilljack Ultra-Low Profile CNC Clamps - Promo - YouTube
