Controller Display Mount
I replaced the display mount for the Buidbotics display on my Machinist. I noticed the back of the display has a 75 mm VESA mounting pattern. I found a dual 75 mm VESA plate assembly on Ebay (RAM-102U-B-2461). It works very well.
The back of the display has a protrusion that prevents the plate from a flush mount. I used a couple pieces of plywood to allow the assembly to be mounted to the display.
The assembly allows the display to be tightened in any position.
On my JM that was just glued on and I was able to pry it off with no damage to the back. Then I used the VESA mount directly.
