was trying to cut a basic circle out of some 1/4"birch. from what I can tell, the rails and jack screws appear to be fine but it’s cutting more of an oval. I forget the axis name, but the axis that’s back and forth or North and South got bound up on me. thoroughly cleaned and manually moved the jackscrews to the front with power off because alignment was a bit off. homed the machine again. but the cut is off. I can’t visually see any issues… anyone got some advice?
Hi Michael,
Welcome to the 1F forum. You can left click on the magnifying glass icon in the upper right corner and type in oval. You will be directed to discussions on that topic.
Hope this helps,
Neil
