I’m about to push the button on a Woodworker. I already have a Shapeoko 3, with a Dewalt DWP611.
My plan is to buy the Woodworker and set it up with the Dewalt, then in a month or so upgrade to a spindle. I know the Dewalt isn’t a great router due to speed control, but I have it available. This will save me $120 for the Makita, which I don’t have an ongoing need for.
Does anyone know if there will be an issue to use the Dewalt Router?
Yes, as @349iq2345 mentioned, the 611 physically won’t work on the 1F (possibly, if you were to get an 80mm spindle holder & make a reducer bushing).
I’ve had both the DeWalt 611 (on my previous X-Carve) and currently use the Makita on my 1F. I couldn’t stand the DeWalt just from the pure noise factor. That thing screamed like a banshee. By comparison, the Makita is nearly whisper quiet.
Here’s a simple adapter ring that may work to adapt a 611 router to an 80mm spindle mount. Would need to make 2, one for top and one for bottom. Small holes are optional for small screws to hold things together. I made something very similar before I got my 1F to adapt a 52mm spindle to the 60mm holder. Made them from corian, but never used them.
Attached file is 69mm I.D. x 80mm O.D. with a 5mm shoulder and a 3mm split for clamping. Might get you by until you get your spindle upgrade (assuming you’d be going with 80mm).
