brandf
(Brandon)
May 25, 2025, 7:08pm
1
Anyone else have an issue where the drag chain slides towards the screws and catches on the back of the frame?
Seemed like it was at risk of breaking if it catches wrong.
I came up with a little workaround by doubling sided taping a plastic sheet to slide it back to the outside before it catches.
Just curious if this was a common issue and if there is a better fix.
JimHatch
(Jim Hatch)
May 26, 2025, 1:45pm
2
Nice clean solution. Clever.
I have read that some users experiencing this have switched out the SHCS for a grub screw which also worked.
Calvin
(Calvin)
May 27, 2025, 3:19am
4
I also have this issue when making rapid movements front to back
I also had this problem. In my case, I replaced the factory screw with an M5 x 10 mm button-head screw. That worked for me, but a grub/set screw that doesn’t protrude at all is probably a better solution.
Yeah me to thinking about a spacers, maybe longer screw
