Dust extraction does not always start
I’ve got an elite foreman with the masso touchscreen, and the corresponding power supply box.
My problem is that sometimes when I start the machine the dust extraction simply will not work - when I hit the ‘coolant flood’ button on F2 the relay in the power supply box does not click and the dust extractor does not start.
Other times I start the machine and hit ‘coolant flood’ and I can hear the relay click and the vacuum starts perfectly.
This leads me to the conclusion that it’s not a fuse issue, because it works sometimes and other times not. I also am fairly sure that it’s not a gcode issue because I’m not running the vacuum from Gcode, but directly from the controller itself.
It feels to me like some kind of software bug, but since no one else seems to have this problem it probably isn’t. I hope someone has the answer, I’m running the dust extractor from an extension half the time, which is pretty annoying!
