E-stop won't release, nothing works anymore (alarm on XYZB)
Hi all, hoping for some help with this problem,
When powering on, and pushing the E-stop, noting happens. The alarms keeps blinkiing. In setup X-Y-Z-B are all in High.
I cannot Home, cannot jog or anything else.
Tried to power off more then 30 seconds
When power off, checked all connections, all seems good.
I’m a bit lost here now.
Your estop is ‘digitally’ inverted. (this usually happens when a user goes into the f1 page of the Masso and starts changing things when they do not know what they do)
You’ll notice it says “Estop - Release button” on the estop button but yours is already released physically.
On the f1 page, the middle line where it says estop, tap that once to select it, then push the space bar. This is switch it back to normal.
You may need to do other operations now that you’ve inverted other lines in f1.
That worked for me! Thanx.
It has something to do with the tool setter, when I home, it does so correctly, but when it sets the height for the tool it doesn’t stop and thus giving an error.
I’ll have a look into that, or maybe you have an idea?
i was that guy, thanks for your information i was able to resolve the problem live and learn but your help is much appreciated thanks again
