E-stop won't reset after moving spindle height up
Long story short, here are the steps I took and the issues I ran into along the way.
Been cutting fine for a month, needed to carve a 2" piece, and had to move the spindle mount up to clear the workpiece.
I moved the spindle up and went to rehome, but obviously, the bit didn’t drop enough on the EZ tool setter to zero out the Z height. Tried to adjust the EZ tool settings in the F1 menu to drop the setting from -1 to -2 to see if that worked for hitting the EZ tool setter. It did not. Seemed to get to the bottom of travel and boom, got a motor alarm for the Z motor.
Tried multiple times to reboot and rehome, but same thing. Now it has triggered an E-stop alarm that I cannot reset, even with the E-stop button. Reboot does the same thing. Currently stuck, not being able to clear the E-stop alarm.
I’ve checked all the motor red/black wires and all are properly set. No red motor alarm lights, I’m stumped.
Thanks for the help!
Jon
Onefinity support helped me quick!
Looks like I had E-stop F1 function in Low instead of High, I switched it, don’t do that. Switched it back and was able to clear the error and rehome.
