I am hoping I can get some help sorting out an issue with an ATC Sensor error.
Specific Problem: When my machine is attempting to load a bit from the #2 slot in the ATC tool holder, the tool appears to be loading correctly but I nevertheless get a “ATC Sensor (Load): Failed to Load Collet” error message, which obviously cancels the machining operation underway.
Background:
I am running a Gen 2 Foreman/ Redline controller and 80mm spindle delivered in March. Because I am new to CNC I took the community advice and ran the machine for a few months using manual tool changes only. I recently installed the ATC module, and got through the setup wizard without any issues. That was followed by a round of 15-20+ successful load/unload/swap operations from the various tool positions. Then on my first actual project using the ATC, the machine got to the 3rd tool change of the file (the bit in slot #2), and I got this Load error message. And since that point I have consistently gotten this error message when loading tools from slot #2 where the other slots are loading without error message. Moreover, in every instance it appears that the collet nut gets loaded correctly from slot #2 despite the sensor error.
What should I be doing to sort this out?
