Elite Journeyman QCW tube between bolt hole dim
Hello,
Does anyone have the bolt to bolt dimension for the Elite Journeyman QCW frame tubes? It should be the same for the tracks but I can’t find that either.
Thanks,
Ryk
On my Journeyman table, which I received 2025.12.02;
Metric: 243mm
Imperial: 9 9/16”
I thought these measurements were odd, I would have expected 245mm or 9.5” for example. In order to double check I measured 3 different ‘bays’ and they were consistent. I also took a total measurement of all 5 bays and it came to 47 13/16” which when divided by 5 yields exactly 9 9/16” so I’m pretty comfortable those numbers are fairly accurate.
I was also having a hard time wrapping my head around the fact the far right and far left bays are wider than the middle three, yet the support slats have a consistent measurement. But the more I thought on that the more sense it made that’s WHY the outer two bays are wider, so that the holes for the support slats CAN be consistent, which would reduce manufacturing costs and production errors.
Cheers.
Thank you! That’s exactly what I needed. Agreed on the table measurements, your explanation makes sense.
