QCW Measurement Not Listed in Specs
CNC Specs.pdf (176.8 KB)
PDF attached:
Does anybody know the specifications for these holes, diameters, how far from the edge…??? And the bolt sizes too?
Thank you so much!
Problem not solved.
I don’t think this is addressing the specific areas and parts pointed out in red in the PDF provided. They certainly are longer than 22mm (0.87 inches)… Those bolts look about 3 inches to me, but I’m just looking at a picture.
I really only need; specifically the measurements for those specific holes and bolts. I think they’re longer than the ones provided in this response. there should be 8 total I think, all the same size.
This is an incredibly informative answer. Thank you so much!
Hi @OnefinityCNC
Is it also possible to get the on-center distances for these holes (in orange) on the Foreman? Please, the distance between the holes on a single block and then the distance between the outside holes on two blocks. Thanks!
