Elite Masso Pendant Estop Behavior
So as i understand this, the pendant estop will stop the movement of the motors, but not instantly. The gcode is read into Masso and the code reads ahead x number of lines so the program finishes those lines of code, which could put you into a crash that you wanted to prevent. The estop on the Touch screen stops you dead in your tracks, and z axis falls. Which is why I whipped up that counter balance system. So all good.
In this link it says black to Estop 1 and green on Estop 2.
https://forums.masso.com.au/threads/onefinity-elite-faqs.3291/#post-24139
Thank you for that link…
From Masso Support to me. " Hi Pat,
Please have the Black wire connected to Estop1 and the Green wire on Estop 2
I moved the pin locations per Masso and everything works as it should. Pendant estop is now stopping motor movement, as well as the console estop.
Spindle does drop due to weight, but that little counter balance i installed arrests the fall of the spindle.
