Whats the best direction to cut holes in MDF or any wood, pocket toolpath with a endmill, climb milling or conventional?
Conventional wisdom is to not use conventional milling on a CNC. That being said there are probably some exceptions.
I would climb mill roughing and then a climb mill finish pass.
Personal preference. You could expect a wee bit more deflection with a climb cut.
