EP. 34 Onefinity Projects - Giant Oreo Stash Box
After rebuilding the drawing (sorry I didn’t like the mis-shapen parts - too many years of doing precision drawings), and adding a wavy edge, mine turned out good and lined up. The trick is precise centering for flipping.
I also made a 4 part ring so I could get the 4 pieces out of a piece of 1x6 instead of wasting a big board.
Thanks!
Pony
I had the same problem. I just made a single cookie with 0-0 in the center for both sides and it worked fine, I’ve made 3 of them and all perfect. Thanks!
On this solemn occasion, here’s an Easter treat for all of you. A Squareo or square Oreo.
All cutting files included, the front and back of the bottom and top are on one drawing, so watch which toolpaths you use. Also, my depth of cuts are fairly aggressive, you may want to change to what you use.
There are 2 holes at the top of the board for bolting to my waste board for flipping, you can eliminate if you don’t use them.
The toolpath labeled ‘Center mark’ puts a dot in the center of the drawing (also for flipping), and 4 dots on the outer edge of the bottom to mark for locating rubber feet. It also puts a 2nd dot off center to indicate down for a label which goes in the 1" recess.
The center is in 4 pieces so I don’t waste wood, this also puts the grain the long direction on all 4 pieces. You may have to lightly sand the grooves to fit, it depends upon the accuracy of your machine.
I show 4 holes for magnets, but I only use 2. You could also eliminate them entirely. I use 1/4" x 1/4" magnets. One TINY drop of superglue holds them in as they are a snug fit.
Enjoy,
Pony
Squareo lid & btm.crv (4.1 MB)
Squareo ring.crv (243 KB)
Squareo ring setup file.crv (546 KB)
I expect this is any easy question but I’ll ask anyway. How did you create the inner ring with male and female dog bone style fillets in the circular model?
Thanks Gerry
I posted this on FB, but I’ll post it here as well. Besides the inlay, my modifications were to curve the outside of the “creamy filling” and cut a grove on the inside of the lids for a more secure fit.
See if the attached pic helps you figure it out. Don’t get confused because something is at an angle.
If you turn the picture 45 degrees so that the lock is vertical, you’ll see how I drew the male lock using circles (I added the red lines to make everything stand out) and Beziers.
Once one lock is made, you turn it 45 degrees, then it’s a simple job of circular copying to create the other 3. Then you use the same drawing to create the female part.
If you don’t want a tight fit, use the offset tool to increase the size of the female part by a tiny bit.
I hope this helps,
Pony
Hi Tony,
I was close, so this makes a lot of sense. Thanks so much for the timely reply.
Gerry
Someone is selling this file on Etsy.
https://www.etsy.com/listing/4311670324/oreo-cnc-file-for-cutting-catch-all-tray?ref=shop_home_feat_4&logging_key=605df463d2ec457bc831da9f85763f3b5e094d50%3A4311670324
Thanks for the info.
I can’t tell by/ a quick look at the Etsy photo if it’s my file or one of the others who’ve posted on here, but just an FYI, when I put a file on here, it’s only for personal and not commercial use and I ask that you respect that.
Everyone who posts drawings on here spends a lot of time and effort to make these and to me, a lot of them are like art and to be respected.
In the commercial world, you’d be amazed at the secret things that are hidden in coding, designs and graphics so fakes can be found. I have markers in my drawings so I know they’re mine for this very reason.
I’ll get off my soapbox now.
Pony
Hey Pony! I love this project and would love to do it. I’m still a bit of a Vcarve novice and I only have 10.5. Is there a way to use your files in an earlier version? Thanks!
You generally can’t use v12 drawings in v10.5, but there is a workaround.
Attached you’ll find a dxf of each, the top and bottom are both in one drawing as they’re the same except for magnet & feet holes holes which are on the opposite sides (BTW, I no longer use the holes or magnets)
You’ll have to create the toolpaths
The entire top design is a pocket cut with 3 bits, 3/16, 1/8, 1/16
The top & bottom outside is cut using a 3/16" bit
The ring is cut with a 1/8" bit
Double up the rings if you want more depth
Pony
3 dxf files will be in the next message
Oreo bottom.pdf (131.0 KB)
Oreo ring.pdf (21.1 KB)
Oreo top.pdf (278.5 KB)
Here’s the dxf’s
Pony
Oreo bottom.dxf (14.1 KB)
Oreo ring.dxf (42.9 KB)
Oreo top.dxf (1.6 MB)
Thanks Pony!! I’ll get to work creating the tool paths. I really appreciate your response.
Great project! The walnut and maple combination looks fantastic, and the Oreo design came out super clean. Thanks for sharing the cut files can’t wait to try this on my machine!
I’m going to make a couple of these for my grandkids. I’m a newbie with both the cnc and carveco. I’m a little confused at the 2 first toolpaths, the 1/8 and the 1/16. Do you keep the whole model selected for both toolpaths?
